Old 01-27-2023, 09:31 PM   #1
Liked 5,145 Times in 1,964 Posts
Default COPO, Drag-Pak, CJ II, (FX) Secrets
I happened to be at Speedworld for one of the first test sessions of the then new blown CJs. John Calvert, Gary Stinnett and a few others were there with the Brent Hajek cars.
The stick cars would just wring the tires off them and wouldn't lift the nose more than an inch. I remember thinking that these cars will be a bear to make consistent and competitive. I know it could be all about the clutch in the stick cars.
Fast forward to today... I see FX cars with big hp and torque numbers cutting great lights and wheelie-ing to lots of dead on runs, and winning eliminators, ..on 9 inch tires.
How is it being done? Timing? Starting out with minus numbers? Boost control? What else?
We hear that the COPOs don't use drive by wire. Do the others?
I'm thinking this thread might belong one floor down, if we get actual tech oriented answers.
Not sure we will. It might take membership in the Six Figures Club to find out ;-)
Old 01-28-2023, 10:40 AM   #2
Billy Nees
Liked 7,849 Times in 1,750 Posts
Default Re: COPO, Drag-Pak, CJ II, (FX) Secrets
I'm pretty sure that the FFFords come as DBWs. I don't know about the DPs but I have heard a rumor that Larry Hill's DP uses a piece of string tied on the TB and looped around his big toe.
Billy Nees 1188 STK, SS
Old 01-28-2023, 10:59 AM   #3
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
I don't know how much of a speed secret it would be,but it couldn't hurt.
The 9 inch tires that you are referring to are not really 9 inch tires.
Goodyear came out with a wider one in 2022,and Hoosier is making an even wider one in 2023.
Old 01-28-2023, 11:29 AM   #4
Smile Re: COPO, Drag-Pak, CJ II, (FX) Secrets
Markie - Did you really think any of us were going to just spit out our secrets??? I'm not so sure that even joining the Six Figure Club will help you .......But I will tell you I don't use DBW in my COPO's.
Old 01-28-2023, 11:47 AM   #5
Jacko, No. Actually I didn't...and so far we're still okay in this section. ;-)
Old 01-28-2023, 01:32 PM   #6
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
I have seen data logs from a Ultra Street NOS car that is around the same weight, that was pulling over 2.2 G's on a 275 DR. If these new tires are lets say 255 I would think a min of 1.95 G's. So just a WAG for the 632.
60 Foot ET = 1.2241
330 Foot ET = 3.4843
1/8 Mile ET = 5.4284
1/8 Mile MPH = 126.1316
1000 Foot ET = 7.1115
1/4 Mile ET = 8.5372
1/4 Mile MPH = 158.1890
Stan
Old 01-28-2023, 02:52 PM   #7
Doug Hoven
Liked 869 Times in 165 Posts
I know the CJs we’re DBW from the factory, but I believe some have converted them to cable. The couple of factory showdown COPOs I have been around we’re all cable throttle. As far as getting down the track, mostly it’s in the tune. A lot of timing pulled on the launch. Not sure about boost control.
1189 F/SA
Defunzalo Racing Enterprises
Old 01-28-2023, 03:52 PM   #8
bigshow2966
Liked 181 Times in 56 Posts
Geoff Turk is really covering the build of his BlackbirdX on Facebook. He hasn't put pedals in it yet, but has started the motor. I would guess his is DBW. They are on a 10.5 tire.
bigshow2966 is offline   Reply With Quote
Old 01-28-2023, 07:28 PM   #9
Keith 944
Keith 944's Avatar
i know jack has nothing to hide as i have seen him blow the tires off many times, however i have been watching a blue cobra jet that leaves like a four cyl. and come alive like a banshee going down track, so if its allowed, dbw, percentage is prob. whats happening, it seemed much more likely than just pulling timing, but is more than certain some form of traction control and from what i saw, it was deadly....
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 01-29-2023, 01:06 AM   #10
GUMP
Liked 2,361 Times in 558 Posts
It really doesn't make a lot of sense to take the throttle out. Modern ECU's have almost infinite control of timing. Shocks, tires, and gearing might want to be added into the equation when trying to figure out what makes the supercharged cars work so well?
I can tell you that every COPO that I have campaigned has run without limiting the throttle by anything other than the drivers foot.
Daren Poole-Adams
NHRA Stock/SS 2007
