Old 01-06-2023, 11:56 AM   #1
dragracerray
dragracerray's Avatar
Liked 217 Times in 93 Posts
Default 2023 COPO Camaro 632
I am curious if we will see any of these in the divisionals or national events this year. Does anyone have there deposit down? Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 01-06-2023, 12:16 PM   #2
Mike Gray
Mike Gray's Avatar
Liked 705 Times in 204 Posts
Default Re: 2023 COPO Camaro 632
Are they in the guide, I see a 572 but not a 632?
Mike 7570 A/SA
Old 01-06-2023, 01:00 PM   #3
Tony Fagnilli
Liked 215 Times in 47 Posts
I was talking to Chevrolet at PRI, and they said that the NHRA was giving them a hard time about acceptance into the guide.
Tony Fagnilli is offline   Reply With Quote
Old 01-06-2023, 01:00 PM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Is it like the Demon, where there is no class that would accommodate the HP/weight ratio?
S/ST 51
S/C 53
Old 01-06-2023, 01:14 PM   #5
Bobby Lundholm
Liked 128 Times in 50 Posts
I read somewhere that it is not NHRA Stock or Super Stock legal.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 01-06-2023, 01:49 PM   #6
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
You know damn well it will be in the guide shortly. GM wouldn't build it if they knew they couldn't race it.
Floyd Staggs 787 SST
Old 01-06-2023, 02:01 PM   #7
GUMP
Liked 2,362 Times in 559 Posts
The NMCA has added it at 530 HP.
It is my understanding that the NHRA doesn't like it.
Daren Poole-Adams
NHRA Stock/SS 2007
GUMP is online now   Reply With Quote
Old 01-06-2023, 09:46 PM   #8
Mike Gray
Mike Gray's Avatar
The 572 (500hp) in FSA has a 9.70 index and will probably run in the high 8’s.
The 632 is more likely a 572 on steroids, 530hp is laughable, more like 1,000hp. I can see NHRA’s problem, where do you put them?
Mike 7570 A/SA
Old 01-06-2023, 09:56 PM   #9
BRETV
Liked 776 Times in 199 Posts
In a naturally aspirated Factory Stock showdown class. Have a supercharged class and a NA class, like they did from the beginning.
Bret Velde
??/SA
BRETV is offline   Reply With Quote
Old 01-06-2023, 10:58 PM   #10
GUMP
The 572 won't get near that as delivered. The original rating submitted was 430 HP, which is a much more realistic number. My 6.2 LT will out run it at C weight....
That 1,000 HP is what the motor made on the dyno. Since when has any Stocker been rated at the TRUE number ?
Daren Poole-Adams
NHRA Stock/SS 2007
