Old 01-02-2023, 02:59 PM   #1
Richard Kay
Liked 19 Times in 9 Posts
Default New Meziere Small Block Mopar Water Pump
New Meziere Water Pump Part# WP114BHD for small block Mopar. Pump was bolted on my motor but never plugged in or run. I have a lower hose fitting for 1.25" hose or you can buy one for whatever size you need. $360 for the pump and if you need the backing plate for use with stock timing case cover I have that for $80. rich1981@optonline.net
Valiantrich
Richard Kay is offline   Reply With Quote
