Old 12-21-2022, 05:04 PM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Updating fuel injection
Is there any power to be had? By updating fuel injection from a older system like a commander 950 to a newer system like a HP, Dominator, FAST ect ect. Or would I better off spending that money somewhere else?
Old 12-21-2022, 06:39 PM   #2
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Default Re: Updating fuel injection
That's kind of like asking if there's any power in carbs..I remember buying an new Q-Jet every winter. Had to have one "just in case". If what you have with your FI is set up really well and follows the target, doesn't have peaks and valleys in the WOT part of the map, then no, you probably aren't going to be in love with much.Most of the old stuff is not set up very well as its lots harder to do.The new systems make it so much easier to get everything out of the tune.Plus three times as quick to set them up.They incorporate a built in data logger, killer shifter programs, nice retards for every gear, comparison tools to quickly compare multiple tunes against one another, idle spark timing that chases your ide to help make it stable and the 02's are quicker at making changes to keep the exhaust on target. Also Injector end tables are available to play with in that you input all your camshaft data/intake runner lengths data and the Holley tries to time the best injection squirt timing. Kind of fun to play with, we have had luck with this on some engines others not so much.
Jeff Niceswanger 3740 SS
Old 12-22-2022, 09:26 AM   #3
Liked 10,759 Times in 2,236 Posts
Thanks Jeff you have said enough.
Old 12-23-2022, 06:37 PM   #4
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Humor a newb question on this. My Escort is running the factory ECM with a backpack plugged onto it. Does a Holley ECM have in it's software the ability to run closed loop @ WOT? The benefits of the Holley system that Jeff is talking about sure make it sound attractive.
Dave Noll, EF/S ,?/SA 6526
Old 12-23-2022, 06:47 PM   #5
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Any aftermarket system should be able to run closed loop at Wot.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
