Old 12-15-2022, 03:28 PM   #1
amp vette
Liked 2 Times in 2 Posts
Default Superstock 350/295 engine
Superstock 350/295 unassembled engine originally built by Hettler-Bowtie block,New .060 Bore and Hone, Bushed lifter bores, 55 mm cam tunnel by Weston Machine, 041 Heads with welded exhaust redone by Dave Jack, Jesel Rockers, ATI Balancer, Jesel Belt Drive, Dart Manifold port matched to heads.
Following are all brand new parts-
(10) CP Pistons with Pins, Two sets of total seal rings, Manley NHRA legal Pro I-Beam rods, Compstar Callies small jrn crank, Chowler lifters, ManleySD valves, Jesel belt, H Bearings, Moroso Superstock big box alum
pan w/pump
Needs valvesprings, pushrods,gaskets and balancing to complete.
Over $15,000.00 parts and machine work.
$13000.00 or B/O
732 266-2598
amp vette is offline   Reply With Quote
