Old 10-27-2022, 09:38 PM   #1
edk68
Default Winter Part Sale
New MSD Plug Wires PN 31193 $70.00 SOLD
New MSD 3 Step PN 8737 $35.00 SOLD
New MSD High Temp Boot Kit Angle PN 8862 $20.00
New MSD Module Kit 11,000 RPM Series $15.00
Used MSD Pro Coil PN 8201 $35.00
New CVR Starter SB Chevy Needs Nose PN 5323 $120.00
Jessel Key way Lifter 8 Center 6 .050 Offset $ 700.00
Jessel Belt Drive Small Block Chrysler R3
New Belt & Crank Seal Bracket for Dist. $900.00 SOLD
Flexalite Trimline electric fan 15" $50.00
New Felpro VC Gasket PN 1646 Sm. Chrysler $ 25.00
Reactor Flywheel 142 T Chevy Bolt SFI" EXP. New $75.00 SOLD
Hurst Line Lock $50.00
9" Richmond 6.50 Pro Gear Lightened small Pinion 9 passes $250.00
2 Angle Tak Window Nets 18" X 23" SFI Exp. $15.00 each
Coan 8" Converter Powerglide stall 6800 $600.00
Comp Cam Push Rods 125 Wall DBL Taper
1 Set of 15 8.100 $100.00
1 Set of 16 8.100 $150.00
Trend Push Rods 125 Wall DBL Taper
16 7.963 $215.00
10 8" $125.00
5 7.963 $65.00
5 7.938 $65.00
16 Unknown MFG 8" $75.00
All Reasonable offers will be accepted.
Contact Ed at 815-909-8827
Buyer pays the ride
edk68 is offline   Reply With Quote
Old 10-27-2022, 11:25 PM   #2
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: Winter Part Sale
Ed P/M sent
