Liked 5 Times in 5 Posts
427/450 Stock eliminator LSX engine - Class winner in 2018 and 2019
Block lightened 28 lbs Custom cam tunnel GP Technologies ported aluminum cylinder heads Victory valves PSI valve springs Jesel 1.9 Aluminum rocker arms Trend custom pushrods – polished tips Jesel custom bronze lifter bushings Stefs performance aluminum fabricated oil pan Scheuman racing custom oil pump cutdown G-rotor gearset with custom pickup ARP cylinder head studs ARP main studs Carillo connecting rods Callies crankshaft – 4” stroke Diamond custom pistons Total seal custom ring package ATI performance balancer with custom hub – heavy inertia weight and heavier durometer rubber Custom designed Cam motion hydraulic roller camshaft Jesel roller lifters GM seamless roller timing chain CFE custom intake Accufab throttle body FAST 65lb @ 58psi injectors Meziere Billet Water pump As tested on 4/25/18 880hp at 7900 RPM 633 lbs ft of torque at 6500 RPM $42,500.00 2 – Lingenfelter billet steel LS block girdles, No hardware – girdles only $500 2 GM truck oil pans (1999-2006) pan only $50.00 each Jesel KDR-57100 lifter retainer set set of 8 –400.00 Jesel PLT-53233 – 475.00 new – set of 8 – 225.00 Jesel Dogbone lifters LFD-44002 – set of 16 – 2500.00 Jesel sportsman rocker arms set with stands - 1.9 ratio for LS DR heads set 800.00
Jeff Myers SS3254 S1522 |
