Liked 223 Times in 28 Posts
2014 Ford Cobra Jet FS/A and also easily fits in Super Stock.
Will sell minus engine, transmission, converter, and Big Stuff3 for $45,000. Car will run -.080 to -.090 under easily without leaning on it in FS/A or FGT/C 302 5.0 Coyote Supercharged engine built by Jimmy Ronzello (JRP Racing Engines out of Michigan). Less than 50 runs since all new. C-4 Transmission built by Joel’s on Joy in Michigan. Less than 50 runs since all fresh. A-1 Torque Converter Currently runs FS/A. NHRA Index is 9.70. Minimum weight is 3595. Advertised HP 525 / Factored HP 571 Can also run in SUPER STOCK by just removing or adding weight and at times, claiming different year for car and engine. The classes it can run are FSS/C, FGT/B, and FGT/C. FSS/C NHRA Index 9.65. Minimum Weight 3385 FGT/B NHRA Index 9.20. Minimum Weight 3420 FGT/C NHRA Index 9.80. Minimum Weight 3670 Built by Darrel Herron for Bo Butner 8.50 NHRA Certified Cage Lamb brakes front and rear (with dual calipers on rear) Lamb master cylinder Weld V-Series Wheels w/ double bead-locks on rear Strange front and rear shocks Hoosier tires front and rear Recaro Cobra Jet seats w/ adjustable slider on driver seat Racepak Udx Dash Display Racepak Sportsman V300SD Big Stuff 3 ECU Precision 3-spd Shifter Strange 9-inch third member Strange 40 spline axles (2) XS 16V Batteries in trunk Aluminum Fuel Cell Aluminum Intercooler Tank Aeromotive Fuel Pump Meziere Intercooler Pump Meziere or CSR Water Pump (I can’t remember for certain which one) Whipple 2.9 Supercharger Contact: Gary Emmons 713-875-9199 cell. Depending on logistics, can possibly be delivered at Dallas National Event, Las Vegas races at the end of the year, or Pomona. Click on the link for Racing Junk ad for photos. https://www.racingjunk.com/stock-sup...31&np_offset=0 Last edited by EMMONS BROS.; 10-05-2022 at 05:54 PM. Reason: Updated rolling price. |
