Old 07-11-2022, 07:57 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default Pushrods, Jesel LS part, misc
Pac valve spring locators 1.270 x .600 x .520 x .060 PN PAC-S128 (new open box) set of 16 - $45.00
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $500 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter – used $50.00
Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends – used but good condition) $50
Trend 7/16 tapered pushrods (qty 16) 9.450 x .165 x 5/16 ends new - $100
Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $100
Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25
Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25
Trend (qty 17) – 9.200 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend (qty 17) – 9.150 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend 9.400 DBL taper .135 wall pushrods 5/16 ends (11) new $100
Trend 9.300 DBL taper .135 wall pushrods 5/16 ends (11) new $100
JRI 2010-2015 Camaro front struts $1000.00 used. Will include choice of:
PAC-14x2.5x150 suspension springs – NEW
PAC-14x2.5x100 suspension springs – Used
2 – Lingenfelter billet steel LS block girdles, No hardware – girdles only $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
Jesel KDR-57100 lifter retainer set set of 8 –400.00
Jesel PLT-53233 – 475.00 new – set of 8 – 225.00
Jesel Dogbone lifters LFD-44002 – set of 16 – 2500.00
Jesel sportsman rocker arms set with stands - 1.9 ratio for LS DR heads set 800.00
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
