Old 06-28-2022, 06:29 PM   #1
Bill Baer
Default 496 bbc
496 Big Block Chevy,( assembled but never started)
.400 tall deck 4 bolt main block ARP main studs*, Callie’s 4-1/4” stroke crank* .400 long eagle rodswith L19 rod bolts*,14:1 JE pistons(4.310 bore) and rings* milodon gear drive, cam motion solid roller cam, fluid damper harmonic balancer , B&B 8 qt. pan with oil heater, Mellings high volume oil pump*, Brodex Heads with Jessel pro shaft rocker arms, Manley valve springs* Titanium retainers 10 degree locks Manton pushrods
ARP cylinder head
& exhaust studs cast aluminum valve covers, Edelbrock 454-TD victor port matched, Moroso distributor hold down clamp&stud ARP stainless steel hardware, MSD distributor
With bronze gear and adapt-a-cap for the large cap, Felpro gaskets
Lifting plate and transport cradle included. (*new )
$7000
Questions please call.
Braidwood, IL 60408
815-546-5413
