Old 06-14-2022, 11:51 PM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default Ford SS and BBC parts
460/300 SS engine complete carb to pan.
Truck block +.070 Total seal rings.
Steel crank Reduced rod size
Comp cams w new Crower lifters Jacques Blais cylinder heads with conical valve springs
Danny Bee belt drive. Roller cam bearings
New Jesel rockers.
Van Lant thermoquad
.85 under in my car bracket mode.
$7500 Sold
Transbrake rollerized c4 2.43 low ( stock ratios) Pro Trans AOD aluminum direct drum $2300
Several small thermoquads by Van Lant $450 each
BBC .400 long rods. Childs and Alberts and Eagle $300
Edelbrock Dual plane manifold BBC. mockup only.
Joe Scott quadrajet off SS BBC $400
Used Jesel rockers CAAS1.70 $35 each
Mike Graham SIX O TWO 540 Four two Six two
Mike Graham is offline   Reply With Quote
