Old 05-25-2022, 12:00 PM   #1
Gale Pinkston
Default Transmission Parts
New ATI 2.08 lightweight gear set with aluminum reverse ring gear $1000 SOLD
Fresh PG transmission TCI aluminum drum - aluminum hub - new ATI 2.08
lightweight gear set with aluminum reverse ring gear $2500 SOLD
New A-1 torque converter 5000 stall $800 SOLD
327 275 hp .060 bore Total Seal Rings with gas port spacers SOLD
CP pistons Crower Billet rods steel Billet cam shaft and tool steel lifters coated Heads Up cylinder heads Comp Roller Rock Arms Comp Push Rods ATI Lightweight Balancer Dart SHP Block $9500.00 Intake to pan FRE
Set of CP 327 pistons with spacers NEW $1500.00 --- AVAILABLE
Gale Pinkston
931-684-4463
Send your cell number to 931-639-7065 and I will send you pictures
931-684-4463
Gale Pinkston is offline   Reply With Quote
