Old 05-05-2022, 05:54 PM   #1
FAragonaJr
Default 1968 Camaro Race Car
FOR SALE
Anyone looking or know of anyone looking for a great bracket car/SG/SST 1968 Camaro here it is.
565 Cubic Inch BBC Engine, Dynoed 930 HP, Only 8 Dyno Ulla and 3 runs on engine, Dart Big M Block, Pro 1 CNC Ported Cylinder Heads, Edlebrock Victor Manifold, Weisco Pistons, Manley Crankshaft, Oliver Connecting Rods, Bullet Roller Canshaft, Jesel Belt Drive & Rocker Arms, Total Seal Piston Rings, BRE 1150 Dominator Carb, BEST OF EVERYTHING.
ATI Powerglide Transmission with Reid Case and ATI Torque Converter,
Dana Rear, Ladder Bar Suspension, Afco Coil Over Rear Shocks, QA1 Front suspension, MSD Ignition, CSR water pump & starter, Magnafuel Quickstar 300 Fuel pump, Powemaster alternator, Winters shifter w/ BRP Air Shifter, Moroso vacuum pump, Lokar Header teathers, Mark Williams quick release steering wheel hub, Digital Delay Mega 200 Delay box and much more!
$29,800
Call or text Frank Aragona Jr. 917-295-2804
More photos, time slips and dyno sheets available!
Only 8 dyno pulls and 2 runs on engine, trans & converter!
2nd pass was 8.902 at 150.92 MPH shutting off early
Name:	1968 Camaro 12.jpg
ID:	62631   Click image for larger version
Name:	1968 Camaro 13.jpg
ID:	62632   Click image for larger version
Name:	1968 Camaro 14.jpg
Name:	1968 Camaro 15.jpg
ID:	62634   Click image for larger version
Name:	1968 Camaro 16.jpg
ID:	62635   Click image for larger version
Name:	1968 Camaro 17.jpg
Name:	1968 Camaro.jpg
ID:	62637   Click image for larger version
Name:	1968 Camaro 2.jpg
ID:	62638   Click image for larger version
Name:	1968 Camaro 3.jpg
FAragonaJr is offline   Reply With Quote
