Old 04-29-2022, 09:14 AM   #1
Gale Pinkston
Default Stock Eliminator Parts for Sell
327 275 hp .060 bore Total Seal Rings with gas port spacers
CP pistons Crower Billet rods steel Billet cam shaft and tool steel lifters coated Heads Up cylinder heads Comp Roller Rock Arms Comp Push Rods ATI Lightweight Balancer Dart SHP Block $10,000.00 Intake to pan FRESH
2.08 gear set with aluminum reverse ring gear--NEW $1,000.00
Small journal 327 crank shaft, standard rod and main $200.00
Rodchester 207 race carb $800.00
Bullit small block chevy cam shaft, .390 .410 lift NEW $100.00
Set of CP 327 pistons with spacers NEW $1600.00
Gale Pinkston
931-684-4463
Send your cell number to 931-639-7065 and I will send you pictures
Gale Pinkston is offline   Reply With Quote
