Old 04-27-2022, 12:33 PM   #1
rod
Liked 20 Times in 15 Posts
Default piston CC ?
stock gen 1 SBC, any idea how many cc's are in the 1 or 4 eyebrows on a stock flat top?
OR, if I put clay in one, and drop it in a cc cup, will the displacement be accurate?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 04-27-2022, 02:41 PM   #2
richie 2
Liked 205 Times in 93 Posts
Default Re: piston CC ?
best is clay i believe. you cant go by manufactures number...
Old 04-27-2022, 02:51 PM   #3
Tim H
Tim H's Avatar
Liked 485 Times in 160 Posts
TRW L2256 4 eyebrow are 6 cc's, but absolutely best idea to measure if possible.
Old 04-28-2022, 07:32 AM   #4
Liked 11,032 Times in 2,267 Posts
I understand how to fix it if cc’s are small, but how do you fix if cc’s are big without changing compression hight or top ring lane dimension ?
Old 04-28-2022, 09:56 AM   #5
richie 2
i dont believe u can...
Old 04-28-2022, 10:24 AM   #6
Greg Reimer 7376
Liked 727 Times in 221 Posts
Cool Re: piston CC ?
Sometimes with a 4 eyebrow flat top piston,327 or a flat top 350,if the valve clearance eyebrows are near or at minimum, and your deck height is near minimum, piston to valve clearance becomes an issue. It then becomes an issue as which method to employ to arrive at the correct piston to valve clearance. Machining the valve clearance notches seem to be the best way to gain piston to valve clearance with the removal of the least amount of metal anyplace else. Excessive deck height gives up a lot, and since the bore diameter is always less than the inner diameter of head gasket bore openings, that would give back even more. Keeping things as close to optimum as far as the total CC's removed is the goal here.
Old 04-28-2022, 11:29 AM   #7
Greg Reimer 7376
In a re evaluation of the 327 275 horse combo for 1968, it calls for a deck height of.002", and a head gasket thickness of .018. I couldn't find a spec for the CC's of the valve notches on the pistons. Experience has taught me that an absolute minimum of about .035" is needed between the top of the piston and the bottom of the cylinder head. I had a 327 years ago with 6 cylinders at .030", one at .028" and another at .026. After a few years of running this thing,I had it apart and noticed that those two pistons had a faint imprint that corresponded with the outline of the combustion chamber. There's no way you could have built this engine with .020" total deck height and run it over about 3000 RPM. Sometimes the engine specs are not always attainable and this is one example. The 350/295 horse has the same spec. One must always remember that despite the engine specs, the laws of physics will ultimately prevail and always win.
Old 04-28-2022, 12:49 PM   #8
mtkawboy
Liked 54 Times in 18 Posts
I know people years back that have tried the .020 total, results were not good
mtkawboy is offline   Reply With Quote
