Liked 75 Times in 28 Posts
Which one seems to work better to activate the 2 step, a button on the pedal, or a pressure switch?
First time out with the new car. I noticed a little hesitation right on the launch, almost like the 2 step was still activated. I currently have a button in the pedal. When I'm releasing the pedal in the garage I notice the button bounces. |
Liked 281 Times in 110 Posts
We have the pressure switch. Leaves very clean
Liked 51 Times in 30 Posts
hi have mine on my brake light switch, a lot of travel very inconsistent, what are you using for a pressure switch?
Liked 870 Times in 165 Posts
I tried the brake light switch setup with the nova. Was a little Leary of the 2 step being activated every time I hit the brakes. Here’s the link to the pressure switch I plumbed in. I know of a handful of racers that use it and have had good results. So far so good with me too. Be sure to get the specific wiring harness when ordering. https://www.automationdirect.com/adc...xoCwCEQAvD_BwE
1189 F/SA Defunzalo Racing Enterprises |
is the one wire switch on most oem (mopar) proprietary valves just a ground to turn dash light on??
Liked 889 Times in 239 Posts
I've used United Electric Controls pressure switch model 10-B12 on quite a few cars ,
Very easy to adjust . shop them online ,not inexpensive ,usually cost around $160, but well worth it .
Liked 54 Times in 8 Posts
Assuming you are using the 2-step for launch control, I think the 12V signal to activate the 2-step should come form the Line-Lock solenoid or the trans-brake solenoid.
If you want it activate from the brake pedal, I would use a 12mm cylindrical proximity switch to drive a relay and use the relay contact to activate the 2-step. Prox switch is easy to fab up a mounting bracket & adjust. Trip point is very repeatable. |
Thank you everyone for the help!
Liked 800 Times in 237 Posts
The adjustable ones from Tansducers Direct work great. -Al
"That'll never work....." |
Liked 627 Times in 156 Posts
Brother, you want to use a pressure switch go the additional mile to ensure the switch only sees ground in first gear. Also a big proponent of wiring different colored indicator LEDs to confirm switch has power (you didn’t stage in 2nd, not that any of us have ever done that, lol) and the second to indicate pressure switch has activated the two step. I am a fan of the IFM ELECTRONIC PK6522 PRESSURE MONITOR but there are other viable solutions.
Pete Lanciers PAL Automotive Racing Stock 7801 |
