Old 04-10-2022, 09:48 AM   #1
Wayne Denklau
Default 283 Super Stock Pistons
used CP Pistons lightened coated offset pins bore size 3.948 piston size 3.942 comp.height 1.590 top and middle ring 7m.m. oil ring 3m.m.250.00 dollars O.B.O.
Bill Miller Pistons 2 Ring lightened and gas ported off set pins piston size 3.935 comp. height 1.590 top ring .043 bottom ring 3 M.M. 200.00 dollars O.B.O,
Bill Miller Pistons offset pins 3.935 comp.height 1.786 .031 dykes 3/16 oil ring no gas port piston size 3.928 100.00 O.B.O.
Bill Miller lightened off set pins piston size 3.927 comp. height 1.786 .o31 dykes 3/16 oil ring 100.00 O.B.O>
set of 8 recondioned Manley Honda Rods for a 265 0r 283 500.00 O.B.O.
2-1957 265 thick wall blocks 548 casting std bore 600.00 for both or 400.00 each
contact Wayne at 402-369-1232
Wayne Denklau is offline   Reply With Quote
