Old 03-22-2022, 01:04 PM   #1
sox
Liked 13 Times in 8 Posts
Default Valve lash question
I read an article on Thermal expansion pertaining to valve lash on mechanical cams. I hate doing valves on a hot engine. Crane cams has a guide that states on a iron block and aluminum heads subtract 0.006 on your hot lash if you want to do them cold. Does anyone go by this.
sox is offline   Reply With Quote
Old 03-22-2022, 01:25 PM   #2
ss chief
Liked 48 Times in 13 Posts
Default Re: Valve lash question
There can be variations between engines and a combination of blocks and heads.
This is what I have done in the past.
Warm up the engine to 150-160, set your hot lash number on one cylinder. Let it sit until it is dead cold. Check the lash and you have determined your cold numbers.
ss chief is offline   Reply With Quote
Old 03-22-2022, 01:33 PM   #3
sox
That’s a great idea. I will try that.
Old 03-22-2022, 02:48 PM   #4
garyc
Liked 51 Times in 30 Posts
most cold lash settings from cam company's are for getting close for starting, they all recommend setting hot for final. that's a good idea for setting hot then check cold
garyc is offline   Reply With Quote
Old 03-22-2022, 09:55 PM   #5
silversedan
Liked 15 Times in 6 Posts
I've used the -.006 rule on my hemi and a wedge and rechecked hot and the results were the same. it's a good rule of thumb after you decide what your valve lash needs to be.
silversedan is offline   Reply With Quote
