Old 03-20-2022, 06:33 PM   #1
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Default Jerico trans, Lakewood bell and clutch for ford
For Sale-
SOLD-Jerico dr-4 transmission with Long pistol grip shifter. 3.19/2.03/1.51/1-1 ratios, 1 3/16" -18 spline input shaft. Just had apart for inspection, sliders, dog and gears are all in good shape. $2800
Lakewood bellhousing for small block ford, like new condition. Includes backing plate, throw-out bearing, Lakewood fork #15525 and is in the Lakewood box. SFI tag is punched April of 2014 $500
SOLD-Ram long style (similar to McLeod soft lok) clutch for small block ford externally balanced (I believe 28 oz), pressure plate has steel ring but I also have a spare alum ring that goes with it, aluminum flywheel, disc measures .317. I took clutch apart, checked everything over, and re adjusted the lever heights. Clutch probably only has 15-20 runs on judging from the wear since it was last fresheend. I also have two extra discs to go with the clutch setup. $500
Call, text or email for more pictures or if you have any questions.
Thanks,
Brad Z
(616)437-4958
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
