Old 11-30-2007, 03:34 PM   #1
vhepower
Default 1969 Roadrunner - Great Stock Potential
1969 Roadrunner, originally a 383 California 4 speed car (Still has 4 speed hump). Currently Vitamin C orange with an AAR 6bbl Scoop,
Interior - 2 drag seats, full upholstery, carpet, headliner, rear view mirror, visors, original dash & intrument cluster, radio taken out and delete plate installed with lighted switches for main power, fuel pump, water pump, radiator fan. MSD 7AL-2, with 2 step, 8 point mild steel cage, dashpad cracked in one place, Autometer playback tach, cheetah reverse valve body shifter w/line lock.
Exterior, engine Bay, trunk - K frame with stock steering system, Comp Engineering 90-10 shocks, aluminum radiator w/fan, overflow can, stock wiring all in place, stock wiring harness and all lights work, drum brakes replaced with disc brake conversion kit, front disc aerospace lightweigt brakes, Trunk is stock with the exception of a 15 gallon fuel cell, blue holley fuel pump, wix fuel filter, 1/2 in super stock fuel line to front passing through passenger side inner fender to a holley regular and two braided lines to carburetor. Moser Dana 60 (2 Years old) 4.56 gears, spool, billet yoke, aluminum cover, 35 spline axles, aerospace disc brakes with big studs, all bullet proof stuff, caltracs, monoleaf springs, Rancho 9 way adjustable shocks, frame connecors, 2 driveshaft loops, chrome moly driveshaft. Rims are weld draglites with moroso DS2 Front runners and Mickey Thompson Drag Radials 295/65/15.
The car weighs around 3,200 without any driver and no weight added. Best time was 10.06 @ 134 with a 1.42 60 foot weighing 3,600 with driver and weight added to make legal class limits. We were just getting a handle on the tune up and probably would have went into the 9's with cool weather.
I can sell the car with a nice hydraulic cam 440 and 727 transmission. I will also be willing to sell the car without parts if not needed.
The paint is 9+ years old and if It was going to be repainted it would need new rear quarters. Nice car with your normal scratches that can be repaired easily. Ready to go stock racing if you choose just drop your motor and transmision in and go to the strip.
The car has been racing in a street legal no power adder class for the past 3 years. Class winner in Rockingam and Mopar Nationals.
Photos available upon request.
$15,000 OBO Roller
s69rr@wirefire.com
304-532-1802 (Cell)
vhepower is offline   Reply With Quote
