Old 02-03-2022, 12:50 PM   #1
Brian Oakes
Liked 436 Times in 116 Posts
Default Winter Garage clean up
1.
2.
3. 12 bolts gears 488 35 runs $200.00
4.
5. used Dana 60 557 gear $200.00
6. 4" M/W Alum. d/shaft 1350 jts 37 1/2 long $400.00
7. 3" Alum d/shaft, small jts and metric yoke $200..
8.
9
10 15x12 satin finished oid school Moniques,drilled 5 1/2 b/s 5x43/4 ,4 1/2 $300.00
11. 16x16 race star double bead locks used 5 ' b/s, 4 3/4 $2400.00
12. 850 holley no choke horn $500.00
13. 850 DaVinci older carb $750.00
14.
15.
16. CSR blue bbc E/water pump $225.00
17. CSR Red sbc E/water pump $22500
18.
19.
20. Aerospace BBC E/water pump $125.00
21.MSD Digital 7 w/ t/ control almost new part #7530t with wiring harness $550.00 SOLD
22.Edelbrock Nitrous Progressive controller new in box part #71900 $400.00
23.4 core copper rad for 69 camaro used very little $350.00
24.
25.
26. MSD 2 step,3 step 40 ea, adj rpm controler 60.00
can deliver anything to Atco open, call or text me, I DO NOT CHECK PM HERE, 407-474-0898 Thanks Brian
Brian Oakes is offline   Reply With Quote
Old 02-14-2022, 10:06 AM   #2
Denny Steward
Denny Steward's Avatar
Liked 131 Times in 24 Posts
Default Re: Winter Garage clean up
how long is the 3 inch aluminum driveshaft?
Denny Steward GT/JA 246
Denny Steward is offline   Reply With Quote
Old 03-09-2022, 12:05 PM   #3
Brian Oakes
Long
