Old 02-02-2022, 06:17 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default Miscellaneous Garage sale parts
Pac valve spring locators 1.270 x .600 x .520 x .060 PN PAC-S128 (new open box) set of 16 - $45.00
Pac titanium valve spring locks 5/16 Mini8 STD PN L8139 new set of 16 $125.00
Pac titanium valve spring locks 5/16 Mini8 +.050 PN L8124 new set of 16 $125.00
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $500 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter – used $50.00
Meziere WN0032S – 1.50 diam water neck fitting black – $10.00
CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends – used but good condition – $30.00
Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends – used but good condition) $50
Trend 7/16 tapered pushrods (qty 16) 9.450 x .165 x 5/16 ends new - $100
Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $100
Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25
Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25
Trend (qty 17) – 9.200 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend (qty 17) – 9.150 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend 9.400 DBL taper .135 wall pushrods 5/16 ends (11) new $100
Trend 9.300 DBL taper .135 wall pushrods 5/16 ends (11) new $100
JRI 2010-2015 Camaro front struts $1000.00 used. Will include choice of:
PAC-14x2.5x150 suspension springs – NEW
PAC-14x2.5x100 suspension springs – Used
LS7 cylinder heads (pair) – unported, has guides and seats. No valves or springs, etc 12578452 – New never used $1500.00
2 – Lingenfelter billet steel LS block girdles, No hardware – girdles only $500
2 GM truck oil pans (1999-2006) pan only $50.00 each
Jesel KDR-57100 lifter retainer set - $500
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
Old 02-03-2022, 12:14 AM   #2
Tony Corley
Liked 61 Times in 25 Posts
Default Re: Miscellaneous Garage sale parts
Message sent on PG
Tony Corley is offline   Reply With Quote
Old 02-03-2022, 04:56 PM   #3
rk3800
Liked 111 Times in 35 Posts
Jeff, I will take the Powerglide. rk3800 at your asking price, please contact me. My cell is 304-549-0193, thanks.
rk3800 is offline   Reply With Quote
