Old 01-28-2022, 01:28 PM   #1
Michael Compton
Liked 59 Times in 13 Posts
Default Winter clearance
- (2) Stroud Window Nets, angled for EastTexas Cavalier, uncertified, $25
- Bickel bearing collar part #JBRC5720, threaded for sensor, new $75
- Bickel bearing collar part #JB5721, threaded for sensor, used $50
- Bickel bearing collar part #JB5721, threaded for sensor, new $75
- Victory Titanium valves, used, 5.55 OAL, ran in Slawko heads, $200
- GRP aluminum rods, part #69559, approximately 60 runs, $200
- BME pistons from 316SBC, 4.060 bore with pins, approx. 60 runs, $200
- HRE intake manifold, used with CFE 10 degree heads, single and dual tops, 8.190 deck, $600
- (2) Patterson 4 hole carb spacer, 4150, $125 each
- JAZ fuel cell cap assembly, new, $35
- Reactor 153 tooth flexplate, expired, $100
- Moroso oil restrictor kit, new in package, #2200, $10
- MSD Ignition Supply Monitor, Part #8974, used $50
- (2) All Star Performance Radio Boxes, #10440, 1.75” with reducer bushing to 1.625”, new, $65 each
- Autometer Quicklite Shift light, new, $50
- Moroso Square O-ring, #97321, new in box, $10
- Autometer mechanical brake pressure gauge, #4426, new in box, $125
- Comp Cams 11/32” Teflon seals with Powerhouse Products install tool, $40
- PAC 1355-16 valve springs, used, 50 runs, $150
- Spectre water neck, swivel, polished aluminum, new in box $25
- MGP rods, 5.46”, 50 runs, $250
- Diamond pistons, 4.074 from 307” SBC, 50 runs, $250
- Ford 9” housing, 4 link brackets, wheelie bar brackets, shock mount brackets, powder coated black, 30” overall width, crack in housing under 4 link bracket, needs welded to fix, $450
- Eibach Platinum barrel springs (2), 16”, 125 pd, P/N 1600.2530.0125, used in 2019 and 2021, $125
Buyer pays shipping. Paypal, check, cashiers check. Contact Michael.compton@sbcglobal.net or 417-437-1669 with questions.
Michael Compton is offline   Reply With Quote
