Are the results from the 60's and 70's national events archived in a location online where stock class wins could be viewed? Thanks in advance.
Liked 747 Times in 362 Posts
If there is, I certainly haven't found it.
The best source I've found is the "Nostalgia Stock & Super Stock" section here. Results are scattered. No particular order whatsoever. Sometimes you'll find class winners, sometimes entry lists, sometimes nat record holders, sometimes event winners. I suppose if you have LOTS of time & are very patient, you could go thru & pick out all the info of interest to you & compile it into some sort of order, so that you could find it quickly, if you wanted to. Would be quite a project. Last edited by oldskool; 01-28-2022 at 10:45 PM. |
Liked 252 Times in 91 Posts
I found a page that lists all the NHRA National Event winners. NHRA published a similar list but I can't locate the current URL. I'm not aware of a single source for class winners.
#4 | |
Tom Kasch has the largest collection of class winners that I know of. Class winner lists are scattered. But if you have enuff time & patience, you can probably gather up quite a few class winners. http://classracer.com/classforum/showthread.php?t=75995 |
#5 | |
Liked 299 Times in 112 Posts
Nice! |
