Old 01-26-2022, 07:06 PM   #1
383nova
Default Nos carbs.
Looking for information on the following CARBS.
Theses are nos holley carbs that i am trying to
Find out if they are used in any class racing.
This is not a for sale ad, information only. What we do not want to do is sell them as just nos carbs if racers van use them.
List:
9834 Julian date 3037
8418-1 jd 961
4781-3 jd 1780
4781-2 jd 2712
3310 jd 923
3310 jd 584
4781-8 jd 2516
4781-2 jd 1758
4881-8 jd 2516
6210-3 jd 2554
Quick Fuel 585
Can someone tell me if this carb number is legal and used on a 1968 or 1969 big block camaro. Stock or superstock.
Thanks for any help. It goes much deeper than you will know.
383nova is offline   Reply With Quote
Old 01-26-2022, 08:18 PM   #2
Chevy55
Banned
Liked 179 Times in 89 Posts
Default Re: Nos carbs.
These are the only Holley #s I found in the NHRA Engine Blueprint Specifications.
1969 Chevrolet
400/427 3-2 Holley F&R R-3659A R-4055A
375/396 1-4 Holley R-4346A
425/427 1*4 Holley R-4346A
430/427 1-4 Holley R-4296A
435/427 3-2 Holley F&R R-3659A C R-4055A
1968 Chevrolet
375/396 1-4 Holley R-4053A
400/427 3-2 Holl F&R R-3659A C R-4055A
425/427 1-4 Holley R-4052A
430/427 1-4 Holley R-4054A
Chevy55 is offline   Reply With Quote
Old 01-27-2022, 09:15 AM   #3
Tom Broome
Liked 88 Times in 43 Posts
When you're unsure of the original specs, parts, or potential OEM application of a specific List Number Holley carburetor, you need the Holley Illustrated Parts & Specs Manual. Available as Holley part number 36-51-7, around 50 bucks from many popular locations (including the Big"A".
I'm sorry, mine's somewhere in storage boxes 500 miles away so I can't look them up for you.
PS If your doing online shopping and it seems like the seller "SuperShops" has lots of Holley 'Group' stuff available, that's because it's.....Holley.
Tom Broome is offline   Reply With Quote
Old 01-27-2022, 11:41 AM   #4
383nova
Thanks the info and the lead on how to find them going forward.
Much appreciated
Old 01-27-2022, 12:51 PM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Read pp.58-62 of this document -
https://www.nhraracer.com/Files/Tech...edProducts.pdf
Also, from the Rule Book, Section 11A, page 3:
"CARBURETOR
Must be correct year, make, and model specified for car’s
engine; fuel or air bleed passages may be resized. Drilling idle
holes in primary throttle blades permitted. Other modifications
prohibited. Sandblasting, grinding, flash removal, dry film
coating, or any other modification to carburetors prohibited.
Replacement carburetors permitted provided they are
same model, type, throttle bore, and venturi size.
Computer
carburetors use latest model non-computer carb for engine
application. " (Emphasis mine)
Old 01-27-2022, 05:37 PM   #6
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
"CARBURETOR
Computer
First part of that; Must be correct year, make, and model specified for car’s
engine; Year was eliminated years back. Model has been modified some. Example; Chevy's can now run a front fuel inlet Qjet instead of 90degree inlet as they came out with. Main thing they do now is measure butterflys, and Venturi's.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 01-28-2022, 08:21 AM   #7
BillK
Liked 30 Times in 17 Posts
List:
9834 Julian date 3037 Universal 600 cfm
8418-1 jd 961 1977 Ford service 460
4781-3 jd 1780 My IP&S book only goes to 4781-2
4781-2 jd 2712 Universal 850cfm double pumper
3310 jd 923 Shows 65 Chevelle 396/425
3310 jd 584 Same
4781-8 jd 2516 " "
4881-8 jd 2516 not in my book
6210-3 jd 2554 1965-70 327-402 650 cfm aftermarket replacement
Quick Fuel 585
From my 1989 Holley Illustrated parts and spec manual
Bill Koustenis
BillK is offline   Reply With Quote
Old 01-28-2022, 08:38 AM   #8
Dwight Southerland
The two 3310 carbs you listed can be used on a 1968 or 1969 big block Camaro using the 396-375 engine or the 1969 Camaro using the 427-425hp engine.
