Old 01-18-2022, 10:25 PM   #1
ab5098
Default afco terminator strut caliper bracket problem
I'm running the Afco terminator strut 30760sc with afco caliper bracket. Strange front brake 4 piston calipers. Problem is with it assembled the brake pads are .250 from going all the way down on the rotor. Like the rotor is too small in diameter but that is the only size rotor they make . I have tried wilwood caliper with same issue. Has anyone else run into this? Afco has been unable to help.
Thanks
ab5098 is offline   Reply With Quote
