Old 01-15-2022, 10:56 PM   #1
Jim Hawkins
Liked 115 Times in 35 Posts
Default sbc super stock cam question
I am changing the cam in my 327/275/295 motor in a 67 camaro. Changing from a stick to a powerglide.
The cam I took out is a bullet 276-285 duration on a 107 lobe center.
Cam was installed with intake lobe degreed at 103.
The cam I am installing is a older comp cam. These are the numbers scribed on it.
2233S/2236S R5
2999A
06063-08
It has 272-276 duration and I believe 105 lobe center.
I will verify when degreeing in.
Question is I have no cam card with timing events and not sure where to install at.
Cam was used in same 327 combo. but with a auto.
Any recommendations on where to degree intake lobe at?
Jim Hawkins is offline   Reply With Quote
