Old 11-02-2021, 09:18 AM   #1
Murray4407
Murray4407's Avatar
Default 36' Gooseneck Race Trailer
• 1993 Timberwolf ( Forest River ) 36’ Gooseneck Race Trailer – Houston, TX 13,500 obo 832-926-3057 - Clear Title
• Used but very solid built trailer. I have another trailer also, only reason for selling is to not pay storage for this one to sit and nothing does well to sit so offering it up while it’s in prime shape.
• 12,000 GVWR , so no need for a one ton dually with this one.
• Unique in the fact you can haul a car and golfcart + have a shower and bed in this short of a trailer.
• Gooseneck setup to tow with a short bed ¾ ton. I use a mega cab no clearance issue even when jackknifed.
• Only issue I know about is some of the clearance lights are in-operable.
• No Leaks. Full walk on roof. I just recoated the seams on the edges with the rubber paint.
• Nice Dip-Zee heavy duty awning ( same brand they install on air-streams everything with it is thick aluminum )
• Fully Insulated and ice cold AC.
• Light and outlet package. Outlets in and out everywhere, there’s 8 or so of them.
• I put on new load range G 14 ply tires , and new bearing and brake assemblies about mid race season this year.
• 4500 Winch
• Elect. Hot Water heater, Shower, sink 25 gallon water tank. Port-o-poti toilet.
• Radio / TV
• Will come with Altalab Trailer Mounted Weather Station ( this is 1000 bucks new )
• Will come with a igen 4500 Quite (Westinghouse / Onan) Generator. Runs the whole trailer and anything I needed to plug in. ( this is 1000 bucks new )
• I attached a picture with all the dimensions.
• Located in Houston, TX - 832-926-3057
• $13,500 OBO. This is a unique trailer with this layout that works perfect for the long weekend races.
ID:	61073   Click image for larger version
ID:	61074   Click image for larger version
ID:	61076   Click image for larger version
ID:	61077   Click image for larger version
ID:	61079   Click image for larger version
ID:	61080   Click image for larger version
Murray4407 is offline   Reply With Quote
Old 11-09-2021, 02:46 PM   #2
Murray4407
Murray4407's Avatar
Default Re: 36' Gooseneck Race Trailer
Sold
