Old 11-25-2007, 01:26 PM   #1
Default Does this make any sense?
"In addition, for the Stock Eliminator category, two-step activation must be by foot operation of brake pedal, clutch pedal, or pressure switch. Hand release prohibited."
So, let me get this straight. If you have a stick shift car, and the two step is hooked to the line lock button, then you have to move it.
You could put another switch under the brake pedal just for the two step. Then, of course you you would have to put another switch on the shifter in 1st gear, so the two step wouldn't activate when you shift second gear (some of us still have to use the clutch to shift)
This is not to be confused with the switch on the shifter for 3rd gear two or three step activation for the burn out.
Or, I guess you can install a pressure switch on the front brake system hooked to the rev limiter .Of course, that would switch off when you release the line lock button, which brings you back to where we started.
Now you have atleast three buttons instead of the one that's already there.
I wonder if they even thought about all of this before they came out with this bogus rule..????
