Old 10-01-2021, 09:35 AM   #1
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Default 291 SBC Super Stock Heads/ Intake/spacer
Ported and Epoxied on the intake side, non welded exhaust ports, chambers polished, full freshen with 30 runs. Comes with matching Victor E intake manifold and blended Qjet Wilson Spacer. Great entry level head to go 6 to 7 under. 1.94 / 1.50 +.100 valves, Isky springs, Titanium retainers. Shipping available on your dime. $2500 USD
327 / 275hp or 350 / 295hp
64 cc chambers
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 10-13-2021, 01:25 PM   #2
kjrvette
Default Re: 291 SBC Super Stock Heads/ Intake/spacer
1/pics of combustion chamber
2/valves brand ,spring seat and open good for .900 lift
3/angle cut
tkhs
kerryrawlick@shaw.ca 6044964888
kjrvette is offline   Reply With Quote
Old 10-17-2021, 06:56 PM   #3
CrateCamaro
3/angle cut
tkhs
Kerry. I'll let you read the add one more time. Clearly states "entry level" heads hence the "entry level" price. Without a calculator handy I'm not sure it's possible to sink the valve into the seat and cut the spring pocket down that far to achieve .900 lift clearance with a +.100 long valve. Once again, these are ENTRY LEVEL SS heads. Next to impossible to find the clean castings, cut and thread the stud bosses, do a competition valve job and install springs/Locks and retainers for what im asking never mind the epoxy work, porting and flow bench time. Plus match the intake and spacer. If you still interested I will send you photos of the chambers to your email provided but if your looking for 7500 dollar top end to be number one qualifier for 2500 dollars these are not the heads for you. Will easilly go 5 under as I did it with a 9 inch tire stocker with 4.88 gears. With more gear it would have been way better but plans changed.
1700 IHRA H/CM
1701 NHRA SS/?A
Old 10-19-2021, 10:23 PM   #4
kjrvette
thks tony for info
