Old 09-06-2021, 02:15 PM   #1
Fred Elsass
Liked 315 Times in 45 Posts
Default In the "old days" !!!!!!!!!!!!!!!!!!!!!!
I am 80 and went down a track in 1960 at Magnolia, Ohio. That was pre- christmas tree.I set my first record in 1973. If your class record was set you had to run off of it like they now do in Combo using index. You also was not allowed to run three classes as you are now by moving weight around. So if someone set your class record at a sea level track in the spring with a density of below sea level and you could not run it your car was junk.
Quit bitching, and go racing.
Sarge
Fred Elsass is offline   Reply With Quote
Old 09-07-2021, 02:54 PM   #2
TGould
Liked 32 Times in 6 Posts
Default Re: In the "old days" !!!!!!!!!!!!!!!!!!!!!!
And, if you ran under in the class final at a National event that was the new record .It happened to me at the 74 Summers.
TGould is offline   Reply With Quote
