Old 08-25-2021, 03:28 PM   #1
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
Default Stock and Super Stock Qualifying Predictions
I put together several predicted qualifying sheets for Stock and Super Stock for the US Nationals. The qualifying sheets were built by using historical run data from February 2019 until August 2021. The Stock database has 40991 runs for this period. The Super Stock database has 31058 runs for this period. This is not all runs for Stock and Super Stock during this period, but is a fairly significant sample size. I scrapped together what all I could find. Of course, some of this data here may not be perfect. I attempted to clean up the data as best as possible. This process simply takes the best run found for a driver number and uses that to build a predicted qualifying sheet. It does not account for density altitude.
ID:	58444   Click image for larger version
ID:	58443   Click image for larger version
ID:	58441   Click image for larger version
ID:	58440   Click image for larger version
ID:	58438   Click image for larger version
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
