Old 11-20-2007, 02:11 PM   #1
gbednar1
Default 1969 Dodge Dart Bracket Car
- 1969 Dart Swinger - Street Legal, Drag car -
Super clean body, NO RUST, Nice paint, Fiberlass hood and bumpers, the rest of the car is steel, all glass is in car and functional. Car is 2950lbs without driver. Engine and trans have a total of 12 - 1/4 mile passes and about 20 street miles on them!
Interior: Custom 8 point cage, window net, Autometer gauges, Dedenbear Delay box, Monster Tach w/MSD shift light, MSD 7AL-2 Ignition, 2 Step,
Engine: Built by Dean Nicopolis - 1970 440 Block and Crank, .030 over, Ross Flat top pistons, 11.5:1 compression, Cometic head gaskets, Manley H-beam rods, Edelbrock ported cylinder heads, Crane gold rockers, Smith Brothers push rods, Ultra dyne .609 lift solid flat tappet cam, 1050 Dominator, Edelbrock Victor Intake, Milodon single line external oil system, Fluiddamper, CSR water pump, Howe aluminum radiator, MSD ProBillet Distributor, MSD Wires, Pro-Parts headers, 3" exhaust system w/Magnaflow stainless mufflers.
Trans: Professionally built 727, Turbo action manual reverse valve body w/brake, Turbo Action 8" convertor, Deep sump pan, Turbo Action Cheetah shifter.
Rear suspension: Dana 60, Ladder bar, Hal single adj. Coil over shocks, Mark Williams 40 spline axles, Mark Williams Spool, 4.56 Pro gear, 29x13.5x15 Hoosier Quick Time Pro tires.
Front suspension: Mopar Performance tortion bars, Koni SPA1 shocks, Moroso Drag Special tires.
Car has run a best of 10:37 @ 127.5 with a 1.39 60' , this was done footbraking the car at 3500 rpm... I have never launched the car off the trans brake yet!
$23,500 or best offer....
gbednar12@comcast.net
gbednar1 is offline   Reply With Quote
Old 11-25-2007, 09:52 PM   #2
gbednar1
Default Re: 1969 Dodge Dart Bracket Car
Sold!
