Old 08-07-2021, 10:55 AM   #1
Matt Welker
Liked 77 Times in 15 Posts
Default Garage Sale, mostly BBC and Camaro parts
3 Weld front wheels, from 69 Camaro, one was bent, appears to have new center and fixed, one has tire and currently a spare, third is used but not damaged $500 for all 3
ECAE BBC Alt Bracket Part 2233, used (I also have 2 different sized belts, one probably fits) $50
69 Camaro Lower Rad Hose 3946039, new $15
69 upper hose curved neck 3909866, looks new but probably used $15
Camaro cowl induction seal part 180235 $30
Moroso trick springs 47000 series, 47150-110, new in box $120
Used Moroso trick springs, cut and belt to fit 68 Camaro, used $20
Tough 1 Starter, part 96222, New $120
Moroso spring perch part no. 85090 $25
BBC block, not decked, STD, 3855961 vette block, $500
BBC block, 3916323 with crank (8904815N nodular iron stock lightweight crank) and pan (spins free), +.030, not decked $400
BBC block 391323, not decked, STD $400
BBC intake 388948 NHRA legal 396/325, passed Indy teardown, ran on 68 Camaro $200
Caltrac complete spring set, LR235-645 P70301 $200
3 215 396/325 heads. Stock, surface rust, been sitting in storage container, $100 each
2 8904815N nodular iron stock lightweight cranks, one has a lot of surface rust, other wrapped in a bag appears to lhave much less surface rust, $100 each
BBC 323 block doesn't appear to have been decked, bore not measured, $250
New Blue Coil Springs, Powder Coated Black, for Camaro SBC, not sure of rate $125 - SOLD
New Landrum 200lb 67-69 Camaro front springs $125 - SOLD
Set of used caltracs for 68 Camaro, complete with block spacer, PLR531-550 LF125-44, brackets strengthened for stick car $300 - SOLD
Extra caltrac half spring set LF125-445 P72610 $100 - SOLD
I can bring to Maple Grove or Indy with payment before I leave. Possible delivery to Dutch, Rockingham, Bristol. If you want it shipped, you pay shipping. Will also be at Fall Carlisle.
Make reasonable offer, these parts needs to go.
I can sent pics, just email matt at welkerlawfirm.com or text 4one0 507 28three7
Matt Welker
Stock 1741, SS/AH 114
www.facebook.com/welkerracing
Matt Welker is offline   Reply With Quote
