Old 07-10-2021, 12:48 PM   #1
kschmalz
Liked 14 Times in 3 Posts
Default Cleaning out sale
Big Block
Chevy Oil Pan - OEM
396 Block, 4 bolt main 3969854 - $750
396 Block 3965961
454 Block, crank and pan 361959 (4280 – 30 over)
290 Oval port cylinder head
4340 Crank - 440-C5-602-6BLT 444041506760
Crank shaft – 1010 GM – 12559354 GR. 0.646
Small Block
Headers- non-step
Merge collectors
Merge collectors 4-into-1, 2 in./18 in.
305 Block
2 pair- 041 cylinder head – clean and checked casting
Heads - 041
Valve covers – Chevy die cast – 4 bolt mount - $35 - pending
Carburetors
Headworth Q-Jet Race carburetor - Good condition $400
Erny Q-Jet Race carburetor - Good condition- $150
2 additional Q-Jet Race carburetor - Good condition - $150 each
Multiple Q-Jet cores – will sell in groups for parts
Transmissions
2- turbo 400 transmissions - cores
2- 350 turbo race transmissions
7 - 350 Chevy transmission cores
1 - 350 Buick/Olds/Pontiac transmission core
2 - power glide cores
Converters – all most likely 4500-5000 stall
8 ¾ turbo converter - rebuilt by JW Performance – R126316 $100
8 ¾ ATI turbo converter – A4235611 - $100 - pending
8 ¾ ATI turbo converter – A4228712 - $100 - pending
8 ¾ COAN turbo converter R110177– $350
8 ¾ turbo converter – 23208XM - $100
8 ¾ C2 turbo converter – $100
Generators
Honda 2000i inverter generator - $700
Predator 3500 inverter generator – next to new – less than 25 hours of run time. $700 - pending
Misc.
Cam 12-000-15, 57895777
Moroso springs – 47140 - $50
Valve covers – Pontiac diecast – new in box - $150 pending
2 - Moon rings
Electric choke – 600CFM square flange (in box) $50
GM Delco trans pan 8655020 – $40
1 pair – SCE copper gaskets 396 –
USED
22431 Takeoff valve springs
Will be at Columbus this week and can bring manageable items- otherwise shipping is extra from 44514.
330-501-5222
kschmalz@gmx.com
kschmalz is offline   Reply With Quote
