Old 06-27-2021, 08:50 PM   #1
Robbie Draughon
Liked 29 Times in 5 Posts
Default 359ci short deck splayed valve engine
359ci aurora block. 4.195 bore 3.250 stroke. Bryant crankshaft honda journals. Grp rods. Billet pistons with 4 spares. .937 keyed jesel lifters. 55mm cam. Jesel belt and distributor. Ati balancer. Msd crank trigger. Peterson wet vac. Moroso aluminum pan. Starter for 142 tooth flywheel. Water pump. Lump cylinder heads. T&D rockers. Sheetmetal intake with Gary Williams dominators. Around 35 runs since freshened. Has run 8.23 in SS/AM in my 66 corvette @2720 lbs.$10,500 Robbie (nine one zero)9882619
SS/AM 2917
Robbie Draughon is offline   Reply With Quote
