Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 06-20-2021, 04:16 PM   #1
Jeff Stout
Liked 708 Times in 285 Posts
Default Coolant recovery on 68 Cutlass
Current set up is 16 lb. cap with the overflow hose going onto ground. With 116 degree outside I'm running 235 and when shut off it will spit out a little. I'm wanting to run a recovery tank but trying find proper radiator cap to let water from tank suck back in. I believe my current cap is 1 way? I think. assuming tank needs hose coming from bottom to always be submerged into water and allow suction back into radiator when cooled.
Old 06-28-2021, 07:44 PM   #2
jimmyparker
Liked 309 Times in 88 Posts
Default Re: Coolant recovery on 68 Cutlass
Jeff, I'm not an expert but I see no one else has responded so I'll give it a shot. First, 235 degrees is pretty hot for an older car and sometimes I would find issues with timing or advance in the distributor especially on Buicks and Oldsmobiles that would effect the running temp. I'm pretty sure we bought recovery kits back in the day which consisted of a recovery tank, hoses, and I think a cap and they may have came from NAPA. The tank was pretty large, at least a quart maybe a little more
jimmyparker is offline   Reply With Quote
Old 06-29-2021, 12:03 AM   #3
Jeff Stout
You are correct. 72 Olds has a recovery system like you described and looks original to the car. I have only been 235 a couple times. With some fluid loss after being shut off. I'm usually 220 with 110 plus outside air and no fluid loss. Just want to be able to stop checking every week and adding some fluid. Would rather capture and send back.
Old 07-20-2021, 11:13 AM   #4
1legjerry
Liked 72 Times in 15 Posts
16lb stant #10231 or 10230 radiator cap
Cheap rcovery tank
https://www.autozone.com/heating-and...87_0?rrec=true
Amazon
1legjerry is offline   Reply With Quote
Old 07-20-2021, 08:03 PM   #5
Mark Ugrich
Liked 71 Times in 38 Posts
Cheap rcovery tank
Amazon
This^^^^^^^^. Only thing I can add is make sure the recovery tank transfer tube is open. I’ve seen some tanks that have the opening molded shut. You’ll wonder why your upper radiator hose is sucked together.
Old 07-29-2021, 10:21 AM   #6
John Kissel
Liked 230 Times in 94 Posts
Go to Year One, and look at # S103,it ain't that much, and look like it should work.
John Kissel is offline   Reply With Quote
Old 07-29-2021, 11:48 AM   #7
Jeff Stout
Thanks everyone. I just sold car today. Heading to Netherland. I was surprised.
