Old 11-16-2007, 11:25 PM   #1
Kingpen
Liked 64 Times in 22 Posts
Talking RARE- Hard to find Blocks
ive been saving these for a while & i guess its time to see if anyone needs these blocks.ALL are vatted magged and i have surfaced most of them ..there are a few that still have original stampings on the i.d. pad.i have finished the bores on most of them but some are still what they were when i got them.................
1969 SBC 4-bolt "3970010" Finished .040 bore,surfaced ,no #'s on pad,May of '69 date-"THE 302 KIND"good mid-year Camaro block
1965 BBC cast # 962 block 4-bolt 396 STD bore- I E code on pad-translates to 425hp Impala.same block many hunt for to put in '65 Vette...B-5-5 date(Feb 5th-1965)--very very hard to find!..........
1968 SBC cast# 386 4-bolt block ---I have 2 of these --- 1 is a Aug & the other is Sept of '68 dates..both are .040 but 1 may have to go to .060 to run.havent got to run a hone through it yet.Both would be good for early '69 Camaro's.both have been surfaced,no #'s on pad.....
Have 2 cast # 870 SBC Sm Jnl 327's..1 is a '64 & other is a '62...both surfaced but havent got to the bores yet other than they are STD but need boring...these are good for early Corvettes.........
1966 cast# 961 396 block (believe its a late '65 date-going from memory) once again surfaced-no #'s on pad.........
1965 cast # 962 BBC 396 block.it has a late '65 date(Nov.) so it was in a '66 model. E F code on front pad--tarnslates to 1966 Chevelle 375hp..4- bolt it is at STD bore 4.250-yes ,someone was running it as a 427 race engine..............
1970 cast# 512 BBC 454 4-bolt block..it has a late '69 date(i think) but was actually in a 1970 454 ss chevelle.i cant remember the code(CRV- i think-dont want to go back outside and look!!) on th pad but it is the 450hp/454 Chevelle block..i put 8 sleeves in it so its back to STD bore(4.250).line honed and still has #'s on front pad. if you are looking for something not on here ,let me know ..i have plenty more blocks but not enough space....email for price at : Vclassman4 @aol.com or put yours on here & ill contact you.........thanks in advance, Vic Penrod S/S 4563
Kingpen is online now   Reply With Quote
