Old 05-27-2021, 08:19 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default 3rd gen Camaro/Firebird ft coil spring tool
Racers, I have the conventional compressor with 4 "fingers" that pull the spring together using a long thread rod. The puller is very old [like me a many of my tools] and I am beginning to fear its failure.
I see talk about an OTC tool that has two disks that pulls the spring together.
Does anyone use that tool. Or other tools?
Larry Woodfin 471W
Old 05-27-2021, 10:57 AM   #2
west coast
Liked 227 Times in 74 Posts
Default Re: 3rd gen Camaro/Firebird ft coil spring tool
Yes the OTC one works great, have no fear when using it laying under a car. It doesnt work in every application, but is great when it does. On a side note working on a 74 GTO it wouldnt work used the kind you are taking about but with only 2 hooks and went through shock hole on frame, some one shared trick of putting heater hose on the coil spring to keep hooks from coming off worked well. I think this tip came from Marty.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 05-27-2021, 11:50 AM   #3
Herbie Null
Herbie Null's Avatar
Liked 439 Times in 69 Posts
Thumbs up Re: 3rd gen Camaro/Firebird ft coil spring tool
The OTC 7045B is the best spring compressor I have ever used on my 3rd Gen, once you use it you will never risk your body to injury again with a hook style compressor tool.. https://www.amazon.com/OTC-7045B-Fro.../dp/B000GTJ5I8 Buy one and never look back.
Herbie Null 201 SS
Herbie Null is offline   Reply With Quote
Old 05-27-2021, 11:42 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
The OTC tool is the one that Randy Manns suggested for my new springs. They are not cheap, but the safest spring compressor I have ever used. It was money well spent.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 05-28-2021, 12:22 AM   #5
Eman
Liked 133 Times in 76 Posts
I have a Snap-On which is a Branick. It has 2 hooks and a slip in fork for the bottom. I've used it on my 3rd gen with Moroso trick springs.
This is the style I have https://www.amazon.com/dp/B08XQVWMN6...=1622175908865
