Old 05-08-2021, 03:38 PM   #1
Tom Young
Liked 19 Times in 9 Posts
Default Heat treating ring and pinion
Who does heat treating on ring and pinions, or whatever process to make them live longer? Sorry if this has been brought up in the past, I could not find anything.
Tom Young is offline   Reply With Quote
Old 05-08-2021, 06:01 PM   #2
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Default Re: Heat treating ring and pinion
I would consider cryogenically treating it. Adds life to most anything.
Old 05-08-2021, 08:27 PM   #3
Tom Young
How is that done, and where?
Old 05-09-2021, 01:36 AM   #4
SSDiv6
Liked 1,607 Times in 584 Posts
The best would be to purchase a new gear set already heat treated from Mark Williams, Indy Gear or Gleason.
I do not recommend heat treating any used set of ring and gears. If they are used, Cryogenics and REM/Micronite finish.
http://www.performancemetal.net
https://www.crownracegears.com/heat_treatment.html
https://www.300below.com/motorsports/
https://negearpolishing.com/services/rear-axles
Old 05-09-2021, 08:27 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Don't forget Tom's Differentials. www.tomsdifferentials.com
Old 05-09-2021, 08:31 AM   #6
Rsmith38
Liked 28 Times in 15 Posts
I have good results from Microblue in Denver NC Have several hundred runs on a Dana 44 and it looks like new.
Rsmith38 is offline   Reply With Quote
Old 05-10-2021, 10:25 PM   #7
Tom Young
Thanks for the input on this. The ring and pinion are new, but a discontinued ratio that is no longer available.
Old 05-11-2021, 12:10 AM   #8
SSDiv6
Tom,
Depending on the brand and supplier, it could be already heat treated.
