Old 05-07-2021, 09:19 PM   #1
ron b
Liked 4 Times in 4 Posts
Default front engine dragster fire suit question
what is the nhra required suit for a naturally asperated front engine dragster running 8.50? i dont have a rule book handy. thanks
ron b is offline   Reply With Quote
Old 05-08-2021, 12:48 PM   #2
Hacksaw
Liked 314 Times in 177 Posts
Default Re: front engine dragster fire suit question
Assuming your trans has a covering, you need jacket and pants Spec. 3.2A/5 and gloves 3.3/1 plus arm restraints. I would double check on this with your Div. director.
Old 05-08-2021, 01:42 PM   #3
ron b
trans has no cover. i dont own the car. i am thinking about buying it. thanks for the reply
Old 05-08-2021, 01:53 PM   #4
FED 387
Liked 336 Times in 183 Posts
ALSO plus neck collar---plus full face helmet WITH face shield--thats for gasoline cars ---you use alcohol or E-85 gas different et of rules--- PLUS you better check all of the previous information again because of the FRONT engine part --- not sure of the trans shield part because it depends on if the trans is in the drivers compartment or not !!!! FED 387
Old 11-05-2021, 01:21 PM   #5
Charlie Yannetti
Liked 192 Times in 83 Posts
I'd want a floor in it for sure.. and I'd be using a Dedenbear or Reid transmission case, as it is between your legs.. if it's certified for 8.50, you probably will not be going 180mph, and will not require a 15 suit, so a 5 suit is OK, unless you feel you want more protection.. don't cheap out on the full face helmet, and consider a HANS device..
How old is the chassis??.. make sure the front end is good, and the length is good for your power.. most front engine cars are short, like 200" to 225".. make sure the chassis cert is current, or you may need a chassis shop to do upgrades..
Charlie Yannetti is offline   Reply With Quote
Old 05-19-2024, 11:31 AM   #6
wideopen231
I think most front engine cars like FED have lot stronger reuirement. I know Jr,fuel cars require sfi 20 suit. SBC with alcohol for most part. I have a 20 suyit and it is PIA but then so is being burnt. I can not remebr seeing a alcohol injected car having huge fire, but I can see where front end hitting wall with fuel tank full of alcohol could be problem.
I have thought about lower nsfi suit for comfort, but always talk myself out of it. Why go with minimum when its your ***** on the line?
wideopen231 is offline   Reply With Quote
