Old 04-18-2021, 12:20 AM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Leaking tire
In the past we coated slicks with a detergent (Dawn?, can't remember) to help seal them up when they had a slow leak. Is there anything better in these modern times??.
Adger Smith (Former SS)
Old 04-18-2021, 12:40 AM   #2
GTX JOHN
Liked 2,486 Times in 697 Posts
Default Re: ll tire
I still use Dawn
John Irving
741 Stock
741 Super Stock
Old 04-18-2021, 12:41 AM   #3
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Leaking tire
Many dish soaps contain oils and skin lubricants to prevent the drying of the hands, therefore, its use is not recommended. Clean both the tire and bead with a solvent such as Acetone, MEK or Ether and use Windex as a lubricant for installing the tire. Do not use tire lubricant either.
If the tire starts to turn on the rim, use 3M Weatherstrip Adhesive or Permatex High Tack gasket sealant around the bead of wheels. Inflate the tires and if possible, let them sit overnight before using them.
Old 04-18-2021, 10:04 AM   #4
Adger Smith
Joe,
It just bubbles out the side wall of a Front MT tire. looks like almost a foam when you soap it. It takes a week for it to leak down enough to even appear it is low on the side wall. These are new tires I bought over a year ago and have not been mounted till last week. Guess I will tube it, but that defeats the purpose of a lite weight wheel and tire.. arg..
Old 04-18-2021, 11:51 AM   #5
SSDiv6
Joe,
Adger,
Many times the bead will get some corrosion and create small and even microscopic pitting that will allow the air to leak. In lieu of a tube, separate the tire from the rim, clean the bead with 500 grit sandpaper, clean both the bead and tire with solvent and apply either weatherstrip adhesive or high-tack adhesive as I suggested earlier. Done this before and it has worked.
Aluminum can be attacked not only by galvanic corrosion , but also by intergranular or exfoliation corrosion when the wheels were formed and the boundary material gets exposed.
Old 04-18-2021, 07:46 PM   #6
Adger Smith
Joe it is up in the side wall. Just under the logo. like the logo in the mold caused an issue with the sidewall sealing off.
Old 04-18-2021, 08:03 PM   #7
BillK
Liked 30 Times in 17 Posts
I dont think I would want to run it like that. Maybe, just maybe after taking it off the wheel and looking at the inside but even then it just isnt worth taking a chance with something happening at speed ?
I know you said you bought them over a year ago but a call to the manufacturer would be my first step if they were mine.
Bill Koustenis
BillK is offline   Reply With Quote
Old 04-18-2021, 08:06 PM   #8
Stewart Way
Liked 70 Times in 22 Posts
We mounted new MT fronts and rears for the Baby Gators. One rear leaked bad on the sidewalls. Took the tire and a bottle of Dawn to the MT trailer and they knocked one side loose and used the Dawn and no more pressure drop. Have use it for decades.
Stewart Way 2424 SS
Old 04-18-2021, 08:35 PM   #9
mschafer
Liked 13 Times in 9 Posts
I used Murphy Oil Soap and Aqua Net hair spray on beads. New tires mounted on new wheels 2 months ago, inflated to 22 Lbs. 2 months ago checked them last week dropped to 18 Lbs.
mschafer is offline   Reply With Quote
Old 04-19-2021, 12:52 AM   #10
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Coca Cola. The regular high sugar one. Slather it up on the sidewall and let it sit in the hot sun for awhile. No leaks anymore.Learned that from a seasoned D6 racer.
Had tried Dawn,Palmolive,Slime. None of them worked. Still weeped through the sidewall,especially on the M/T's.
Permatex High Tack brush on in the can stopped the tire from turning on the rim. Had tried the Aqua net and one of them was turning 3" on the first hit.
55 Chevy is offline   Reply With Quote
