Old 03-31-2021, 08:25 AM   #1
garyc
Liked 51 Times in 30 Posts
Default mopar rear axle
Hello,
what are you using for rear axle assy for L M/SA? 4000lb car, will a 8 1/4 work? c-clip? 4:88's ? I can deal with changing ring/pinion each season just don't want to spit pinion out on starting line
building 1975 cordoba 400 4V for L/M
thanks gary
garyc is offline   Reply With Quote
Old 03-31-2021, 12:52 PM   #2
Demon340
Liked 108 Times in 29 Posts
Default Re: mopar rear axle
Originally Posted by garyc View Post
Hello,
thanks gary
Moser 8 3/4
Drop out center section. Will hold up for a long time.
Demon340 is offline   Reply With Quote
Old 03-31-2021, 01:22 PM   #3
GTX JOHN
Liked 2,487 Times in 698 Posts
I run a N/O/P Mopar
@ 3500 to 3700 Lbs.
I would strong recommend to 8 3/4
The 8 1/4 is had to find gears for and
really much weaker!
Even in the Mid 70's Larry Shepard at the Mopar
Performance Seminars strong recommended losing
the 8 1/4
He stated that Mopar save a little over a single dollar
when they replaced the 8 3/4 with the 8 1/4. I guess
every dollar counted with a Mfg. that was bleeding money
at that time!
John Irving
741 Stock
741 Super Stock
Old 04-01-2021, 12:10 AM   #4
GTX JOHN
My boy runs a 400 Roadrunner usually in I/SA at around 3700 Lbs
We have broken several expensive 8 3/4 third members before we went
to a Dana 60.
John Irving
741 Stock
741 Super Stock
Old 04-01-2021, 10:10 AM   #5
Race Clean
Liked 129 Times in 53 Posts
It's the weight you should go by,Heavy = Dana
Based on my observations a 283 in a heavy Car could be thougher on rears than a 396/427 in a lighter car.
Trying to move a lot of weight from standstill in a hurry is what takes a toll on stuff.
My experience with 8 3/4 is that they start breakin up around 3500 pounds and even earlier if you have some serious power.
Then some say the Dana is faster also...sorry about the rambling,your question was about the 8 1/4 and 8 3/4 and I have zero experience with the first one!
Stop global whining
Race Clean is offline   Reply With Quote
Old 04-01-2021, 10:54 AM   #6
mopacltd
Liked 124 Times in 44 Posts
My experience is with the length. Axle tube flex caused most of the failure.
mopacltd is offline   Reply With Quote
Old 04-01-2021, 11:56 AM   #7
340Cuda
Liked 805 Times in 341 Posts
My personal experience was that the extra performance of the Dana 60 made up for it's increased weight. The car did not slow down a bit. That seems to be most folks experience. If you can take out ballast to make up for the increased weight folks report the car picking up.
Of course changing the ratio in a Dana is a much bigger deal than a 8 3/4.
Your mileage may vary.
Bill
Old 04-01-2021, 03:53 PM   #8
garyc
GTX john hit the nail on the head D60 it is
Old 04-02-2021, 08:39 AM   #9
Liked 10,769 Times in 2,238 Posts
Dana 60 is faster and more cost effective. First ring and pinion lasted 19 plus years in the CUDA from 3800 lbs in C/SA to A/SA at 3200 lbs. Ask Chuck Beach with his 340 car.
Old 04-02-2021, 01:07 PM   #10
Frank Castros
Dana 60, set it and forget it.
