Old 03-26-2021, 09:47 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Ultrasonic cleaner for small parts
I am in the market for an Ultrasonic cleaner with a tank large enough for a Holley carb body, throttle plate, fuel bowels, other small automotive parts.
Does anyone on this board use such a cleaner? Size and brand recommendation?
Larry Woodfin 471W
Old 03-27-2021, 11:31 AM   #2
SSDiv6
Default Re: Ultrasonic cleaner for small parts
Amazon sells several that work great. Just make sure you use the right cleaning solution.
https://www.amazon.com/Ultrasonic-St.../dp/B00T8O91WM
Old 03-30-2021, 11:04 AM   #3
MIKE3554
Ultrasonics,LLC. They have one big enough to put a Dominator in. They also have the cleaner.
MIKE3554 is offline   Reply With Quote
Old 03-30-2021, 09:24 PM   #4
Gmirza
Liked 253 Times in 95 Posts
Branson 5200 is big enough to hold a Holley center section. L&R Quantrex 5280 is about the same size. We use them for cleaning small parts. Some of the ultrasonics also have heaters, these don’t.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 03-30-2021, 11:15 PM   #5
Jeff Stout
Liked 705 Times in 282 Posts
Never thought of this before. Will it clean dirt, grease, and grime, rust? Will machine need cleaning as the sediment I'm sure fall to bottom of container.
Old 03-31-2021, 10:36 AM   #6
Dragsinger
Jeff, my fact-finding mission shows these to be the cat's meow
Larry Woodfin 471W
Old 03-31-2021, 10:41 AM   #7
Dragsinger
As an aside, I began looking for alternate carb cleaning methods because my wife has serious complaints about the old-timey carb dip solutions. And I agree. It smells to high heaven and takes days to dissipate.
It will not wash off, and it wears off over several days.
Larry Woodfin 471W
Old 03-31-2021, 12:16 PM   #8
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
I bought one to clean up a pair of WCFB for a 283 245hp street setup and it works good.
Tried Simple Green and also aircraft grade simple green, both mixed down with water and both seemed to provide the same cleaning.
Tip - pull the parts out right when the timer cuts out and blow the parts off with air. If they sit in the basket too long the particles suspended in the cleaner solution will land back on the parts.
Also, I would run the larger carb body parts a few times rotating the part upside down and other angles as that seems to clean better.
Get one with the solution heater, it may take a few cycles like I mentioned, but the heat does help break down the dirt.
Plan on draining and cleaning out the tub after every 3-5 cycles as the water will get very dark.
Chad E532 is offline   Reply With Quote
Old 03-31-2021, 01:06 PM   #9
Dragsinger
Chad, what size and brand did you buy? And from who?
Larry Woodfin 471W
Old 03-31-2021, 03:25 PM   #10
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
I purchased this model 4 years ago. It has 4 transducers, adjustable heater, and holds 2.5 gallons.
https://www.ebay.com/itm/10L-Liter-S...cAAOSwfz9gGKb3
It has worked well and I've had no issues. I use it for cleaning transmission bolts and other small transmission parts while the larger parts are going around in my jet spray cabinet. I use the same Zep chemical in the ultrasonic cleaner that I use in the large jet spray cabinet. I have used this to clean carbs as well. What I have found is using my soda blast cabinet works well to clean a carb prior to running through the ultrasonic cleaner. As mentioned by someone else, once the cycle is complete, remove the items from the cleaner. If you don't, the suspended particles will fall and attach themselves back onto your parts.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
