Liked 503 Times in 131 Posts
Anybody have a good tire pump lead to get those tires up to 120Lbs? Alternatively a good method that doesn't DEFLATE your tire using the on board RV air compressor?
Thanks Eric
Eric Merryfield 1883 STK |
Liked 361 Times in 140 Posts
Eric, most of the guys that I RV with carry a “pancake” style electric compressor like this:
https://www.tractorsupply.com/tsc/pr...CABEgI_lfD_BwE Or, this one is super handy if you don't mind the expense: https://www.amazon.com/VIAIR-400P-Au...ag=googhydr-20 I, personally, air mine up to 110 to 115psi with the onboard air system because it goes through an air dryer and imo is better than a compressor. Yes, it’s slow! You have to pump the brakes on the mh until the compressor kicks in but it works. Last edited by 1matcoman; 02-23-2021 at 06:41 PM. |
Liked 3,244 Times in 986 Posts
I use the pancake style also, depending on your valve stem/wheels in dual rear wheels a gauge similar to this is great for hard to reach spots.
https://www.amazon.com/gp/product/B0...ref_=pd_gw_unk
#4 | |
Liked 335 Times in 182 Posts
The pancake compressor is not going to do the job!!! First the recovery rate is going to take too long (2.3CFM)and the upper limit of them is only about 150 PSI-- it will take you forever to do anything .---Are you talking 22.5 TRUCK tires like on a Diesel Pusher MH or tires on a Class A or Class C that take 90-100 PSI ????----you are going to need a Compressor !!!!! not a flyweight pancake unit-- Save your money on this--FED 387
#6 | |
While I will admit that this is not the ideal way to add air to a 22.5 motorhome and/or truck tire, it will most definitely do the job. I have seen it dozens if not hundreds of times. I don't see to many motorhomes with enough room to carry a large compressor, so these little portable units work just fine. |
Liked 136 Times in 49 Posts
One thing to look into when shopping for the pancake compressors is to make sure they have a relief that releases the air when the compressor shuts off. It makes a big difference if you are running it off of a generator. I have Craftsmen that has it and can easily run it off a 3500 what generator. I friend bought the harbor freight version. And his would about kill a 4500 watt generator if he tried to start it with pressure in the tank.
