Old 02-20-2021, 12:02 PM   #1
Charlie Laraia
Default Motive Gear FORD 9 INCH 5.00 F890500AX – RING AND PINION
Motive Gear FORD 9 INCH 5.00 F890500AX – Performance Ring and Pinion Set
Brand: Motive Gear
Manufacturer's Part Number: F890500AX
Part Type: Ring and Pinion Gears
Differential Case Design Type: Ford 9 in.
Ring and Pinion Ratio: 5.00:1
Ring Gear Bolts: 10
Pinion Spline Count: 28
Ring Gear Rotation: Standard
Ring Gear Teeth: 35
Pinion Gear Teeth: 7
Ring Gear Diameter (in): 9.000 in.
Pinion Shaft Diameter (in): 1.313 in.
Notes: AX series ring and pinion. Requires the use of Daytona pinion support and solid spacer kit.
This gear set is used but in “as new” condition.
The gear set was professionally set up, broken in correctly, and has very little street driven use only.
This gear set sells new for over $400 at Summit or Jegs.
Will sell for $300 with free shipping! (PAYPAL)
860-614-2252
CLML5594@gmail.com
Charlie Laraia is offline   Reply With Quote
