Old 01-21-2021, 07:40 PM   #1
Jared Jordan
Liked 539 Times in 120 Posts
Send a message via AIM to Jared Jordan
Default 426 Street Wedge 365/291 Engine/Converter
Looking to sell the combination that I've been running the past couple of years in my '64 Dodge 330. Complete from carburetor to oil pan. Will include the torque converter that's in the car now for some extra $$ along with providing the buyer the transmission/differential ratios I'm currently using.
426 Street Wedge Stocker Engine:
Factory Rated 365/NHRA Rating 291
Fits G/H/I in a '64 or '65 car (min. 3515 lbs in H/SA)
- Built by John Shaul
- Cylinder heads by Don Little
- CP Pistons
- Shubeck Lifters
- Deep pan
- Carter AFB by Shaul
Engine has approx. 100 runs on it. Has had 0w-5 weight oil in it for exactly two passes in its lifetime and runs at least as good now as it did when it was brand new off the dyno. Will supply buyer with RacePak data. Oil pressure literally never wavers.
Best 60' to date is a 1.393 in H/SA. It went 10.97 @ 118+ in Sacramento on 12/5/20 at minimum H/SA weight, with no light oil or chiller on a day with 1000' DA and a slight headwind. It'll easily go -1.3x under the index on kill.
$17,500 for the engine carb to pan
$18,500 with the torque converter and gear ratio info
$21,000 with converter and stainless Tri-y's from Performance Welding.
Call Jared @ 209-765-9718. If I can't answer your question, I'll put you in touch with the right person that can.
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
Old 01-23-2021, 04:58 PM   #2
Jared Jordan
Default Re: 426 Street Wedge 365/291 Engine/Converter
Sold. Thanks ClassRacer!
Jared Jordan
9 B/SA
