Old 01-02-2021, 04:13 PM   #1
bman3040
Liked 2 Times in 1 Post
Default COPO/LSX Parts
1-set, Brand NEW LSX cylinder heads, never used,bare, ported from GM for supercharged COPO…$1,900
1-set Used LSX cylinder heads, fresh valve job, complete and assembled with valves and springs, ported from GM for supercharged COPO, machined for Jesel shaft style rockers, Race ready…$2800
1-Used Callies Dragonslayer crank for supercharged 350 COPO only 30 runs on it…$750
1-Used LSX steel block, 4.130 bore, dyno time only, has some water spots in a few cylinders due to losing a head gasket. Just needs a fresh hone to clean up…$1750
1-set Strange double adjustable front struts with Hypercoil springs came in a ’17 COPO…$650
1-Strange center section, Aluminum case 35-spline, 4.28 gear, barely used…$950
1-Weld COPO Delta rear beadlock wheel, polished, off a ’14 COPO. Only have one wheel…$1200
1-set Fuel injector clinic 95lb/hr injectors set of 8 for LS3/7/9 engine, barely used…$500
1-set Injector Dynamics ID1300x injectors. Set of 8 1340cc Injectors for LS3/7/9 engine barely used…$1200
1-Kaase Race engines 350 Supercharged engine. 590HP rated, made 1241 on their Dyno with Whipple blower, never been in a car, Dyno time only. Selling without blower assembly, ie complete long-block only. Jesel valvetrain, Stefs pan, Comp roller cam, lifters, etc. Killer Stock/Super Stock engine…$24,000
For more info or pics email Bruno Massel at Bman3040@comcast.net or call 630-458-0043.
bman3040 is offline   Reply With Quote
