Old 12-18-2020, 12:29 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default 73/74 nova stocker
73 nova non hatchback that can run as a 74. Lots of nice parts on this car. Engine and trans is far from anything trick, runs 3ish tenths under in H 60lbs heavy(160lbs in box and I weigh 250). This car is factored less than the hatchback car. Can go from F to I depending on year claimed and will make F weight
Autometer Ulitmate Playback tach
Del a lum upper and lower control arm bushing and billet upper shafts
2 step with adjustable brake pressure switch and high gear cancel switch on shifter
Strange front brakes
Afco DA front shocks
Landrum front springs
Nice swingout roll bar
Aerospace rear brakes
Well prepared moser 8.5 10 bolt
Caltracs and Calvert Adj shocks
Magnafuel pump
All the floors were replaced so no rust in this car
Engine
Gm crank 3.493
Eagle rods with cap screws
Ross pistons
New Total seal rings
Bullet cam
Fresh 993 heads with decent work, screw in studs
Spare 882 heads fresh but need intake cut to fit
Spare intake
Trans
200 metric fresh with Sepenak manual VB
UCC converter fresh
Click this link for pics https://photos.app.goo.gl/Sr2BKNvKNdNS8T4TA
$17000 obo Can include a 28ft Pace enclosed trailer with AC, fold out couch, power awning, for $24500 total package with 5 gal of c12 and all the lead weight you would need
jamie2370 is offline   Reply With Quote
