Old 12-15-2020, 10:34 PM   #1
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
Default WTB: SBC Plug for distributor
looking for a distributor plug for a small block Chevy.
i have a front drive distributor.
Bob Lasko
lasko@optonline.net
203-+858-19552
Bob Lasko is online now   Reply With Quote
Old 12-16-2020, 08:22 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Default Re: WTB: SBC Plug for distributor
MSD sells them
Mike Pearson 2485 SS
Old 12-16-2020, 11:44 AM   #3
SSDiv6
Liked 1,603 Times in 583 Posts
Bob Lasko
lasko@optonline.net
203-+858-19552
Do you have internal or external oil pump?
Old 12-16-2020, 02:09 PM   #4
Bob Lasko
Bob Lasko's Avatar
i have a external pump.
this is for my backup engine
Old 12-16-2020, 03:09 PM   #5
FED 387
Liked 333 Times in 180 Posts
Bob ---Best way to do this if you have access to a lathe is ---measure the diameter of the hole and add about 1/2 inch to that measurement--then turn a small piece of aluminum stock about 1 1/2 inch long to the inside hole dimension leaving some extra material also about 1/2 inch on one end --this larger end will be the top of the plug--the thinner part is going to go into the hole the larger part is going to sit on the top of the block and the hold down is going to rest on this collar---you can use a stock distributor gasket to prevent leaking OR machine 2 groves in the plug you just made and install or-rings to keep the plug from leaking--should not take more than 15-20 minutes to do it this way---Cheap and easy -- otherwise you are going to spend $$$ to buy a plug from Moros or somebody that includes the oil pump drive which you don't need cuz of the external oil pump drive ---FED 387
Old 12-16-2020, 04:09 PM   #6
FED 387
If you want to get a MSD one its a MSD #8512 --- my plug idea" Will work" as long as you are not using a Dart Little M block or any block that oils from the front to the back-if you have a front to back oil system and/or an internal oil pump then you will need to use the MSD plug for the proper oiling--FED 387
Old 12-19-2020, 10:57 AM   #7
Bob Lasko
Bob Lasko's Avatar
Thanks for the advice.
Do not have the access to a lathe, have to buy from msd.
Thanks to all and a Merry Christmas
Bob
